How important is it to fix the clicking or clunking clutch?
Old May 9, 2006 | 02:38 PM
farmboy1976's Avatar
Default How important is it to fix the clicking or clunking clutch?
I have the clutch noise on my 1997 425 magnum, think it is those spider buttons that everyone has been talking about. How crutial is it to have that problem fixed? What kind of a project is it? It's the noise that goes away on idle and when there is load on the engine is a bit more prevalent.
Thanks for your help in advance.
Farmboy
Old May 9, 2006 | 11:13 PM
2manytoys's Avatar
The famous polaris clutch chatter is usually heard only at idle but once under load it goes away. You may have a different problem. But the buttons should be replaced regardless because it will tear up the primary.
Old May 10, 2006 | 09:34 AM
Kerbbirds's Avatar
Non EBS buttons are $3.00 each, take off the clutch cover, pull off the secendary clutch, turn it upside down,remove the snap ring and the helix will turn and come up out of clutch. the spring will lift out, see what holes it is in before you remove it. Youl see three buttons under helix, change them, check your helix for exessive wear, clean it all up and put it back together, turn the helix clockwise 1/3 turn then push it onto shaft and put snap ring on, this takes some strength, might need another person for snap ring duties, I've done it myself but it is better with help.
Old May 10, 2006 | 09:43 AM
2manytoys's Avatar
Yes there are also secondary buttons to be replaced but it is the primary buttons that make the noise and will tear the clutch up.
Old May 10, 2006 | 03:44 PM
2000scrammy's Avatar
You should look into your belt condition. I just had something like that too and I found chuncks of my belt laying on my head. It was a rythmic tapping, clicking, or clunking that didn't happen at idle and got faster the faster you drove or revved it up. The belt had a tail that was ripped and it clunks when it hits the pvt case.
Old May 11, 2006 | 11:40 AM
Do you know if the scrammy can be swapped with the clutch on the 425, I got a guy that has one in good shape and thought that would be easier then fixing those buttons, I don't have a good gear puller and would probably make matters worse trying to fix the buttons.
Thanks.
Old May 11, 2006 | 07:34 PM
ftwflh's Avatar
The clutches will interchange.I would invest in a puller ($30) Whrn you get the Scrammy clutch if it is a 400 scrambler clutch swap your weights out and use the scrammy spring.If it is a 500 scrambler clutch just use it as is.
fordfaithful21
Dec 7, 2015 05:52 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
