98 Polaris 500 Sportsman Explorer ?????
Old Jun 8, 2006 | 01:34 AM
cowlamb's Avatar
Default 98 Polaris 500 Sportsman Explorer ?????
OK, thnx hopefully it goes cheap and isn`t to junky:-D
But if it was the belt that was smoking not the engine what would cause it to slip so much??
Old Jun 8, 2006 | 10:38 AM
400L4x4's Avatar
I dont know about the belt but if you drive the atv slow it will warp the plastic clutch cover
and the primary clutch will rub and wear away the cover.
That might be what is causing the smoke.
Old Jun 8, 2006 | 10:41 AM
mtpockets's Avatar
Originally posted by: cowlamb
this is the reply i got.
That bike was a nice bike a few years ago. I can tell you that I
started it, it turned over just fine. It goes into Low gear but struggles
(belt/chain not driving) It'll catch for a little while, then loose it
and start smoking. The 4x4 worked as far as I could tell. It doesn't
want to catch at all In Reverse or High gear (grinds). The ignition is
torn apart, but it starts in a pull or two manually. I had it looked at
and they agreed it needed tranny work. Other than this I don't know.
Ignition, trans, and any part that would be melted or damaged by that
what would you think the problem is?
after reading the above i would offer $100 Canadian for it! it has so many problems.....and those are just the ones they have told you about. i'm sure there are more!
Old Jun 8, 2006 | 10:43 AM
mtpockets's Avatar
"1998 Polaris 500 Sportsman Explorer "
there is no such model. it's either a Sportsman OR an Explorer.
Old Jun 8, 2006 | 10:59 AM
  #15
cowlamb's Avatar
How does riding it slow warp the cover??
When i see it, what things should i check on it?
Old Jun 8, 2006 | 12:20 PM
  #16
400L4x4's Avatar
I dont know how but from my experience and other friends that have polaris' and the mechanic said that riding under around 15mph will make the cover warp.
Things to check for:Tire condition
4x4 drive system
Engine Condition
Body Condition
Old Jun 8, 2006 | 02:51 PM
  #17
cowlamb's Avatar
forgive the newbish question but how do you check the 4x4 system and the body? what things do i look at?
thnx
-Calum
Old Jun 8, 2006 | 02:57 PM
  #18
400L4x4's Avatar
The body you need to look for cracks,how bad it is faded,pretty much how picky you are makes the difference.
on my 4x4 you can tell if the 4x4 is working by moving a sprocket and if all wheels turn
if the 4x4 button is engaged.You cant do that with yours though cause it is shaft driven.If it moves under its own power if the tranny isnt screwed up put it on jacks,turn the 4x4 on and see if four wheels turn.
Old Jun 8, 2006 | 04:28 PM
  #19
cowlamb's Avatar
ok thnx.
I am gonna phone around find out how much a tranny is here. then we`ll see:-)
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
