Reverse rev override question.
Old Jul 5, 2006 | 04:12 PM
vbgagnon's Avatar
Default Reverse rev override
I've done some searching and haven't found what I need. All the threads talk about newer bikes. I've got a 2002 sp 700 and I want to be able to override the toggle when I plow, but when I'm not plowing I want it to operate like normal. I was thinking about getting a few switches and wiring it up that way but I'm not sure what to do about the wire that has to go to the power.
The reason I want it to be able to go to normal is because I've got a son who is going to be using the bike in the future and don't want him to get hurt. Any help would be appreciated.
Old Jul 5, 2006 | 04:25 PM
NLWarrior01's Avatar
Default Reverse rev override question.
clicky
Have you tried quadovator's web site? I'm not sure but I believe their product might do what you want (though they too may be geared to the newer sportsman's)
Old Jul 5, 2006 | 04:33 PM
SafetySean's Avatar
They should have a kit for you. Warrior I've got one on mine...dead simple to install( 5 mins) and works like a charm
Old Jul 5, 2006 | 04:38 PM
vbgagnon's Avatar
Is there any way I can do this myslef? Instead of waiting for it to ship and all that fun stuff.
Old Jul 5, 2006 | 05:12 PM
crashby's Avatar
just put a zip tie on it when your plowing
Old Jul 5, 2006 | 10:11 PM
ox's Avatar
ox
Not sure how easy it is to get to your rev limiter - but on the Scrambler / TrailBlazer it is pretty easy. If you unplug - OR EVEN just unscrew and set aside (so's it don't get no ground.) it won't limit you.
You could actually mount it somehow that it's not grounded and just attach a wire to it to go to a switch on the dash and run that to ground.
Old Jul 5, 2006 | 10:17 PM
ricknzep's Avatar
I've done the zip tie trick and it works fine. Does anyone know where the limiter is located on 2002 models? i have a 500HO, but i'm sure they are all in the same place. Thanks.
Old Jul 5, 2006 | 10:40 PM
rodknocker's Avatar
if you want to overide to work when you are riding and not when plowing just add a toggle switch to the circut on my 04 sportsman 700 the wire colors are brown and gray/orange just splice in a switch and turn it on when you plow and its just like holding the button
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
bigred20653
Oct 2, 2015 10:05 AM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
