antifreeze
Old Jul 11, 2006 | 12:46 PM
madmatt1971's Avatar
Default antifreeze
Taildog,
Please get us a link to your origional post. I'm in water all the time and I'd hate to have to repalce my H2O pump seals THanks.
Old Jul 13, 2006 | 12:46 AM
Traildog's Avatar
Default antifreeze
Sorry for the late reply but it took me a while to find the file.
I wrote this article a few years ago on another forum and as you can see a piece was added by the administrator explaining an option for connecting the tubing. Since I modified my quad 4 years ago I have not had a water pump failure which is a testament to the mod.
Here's a couple of tips that will help to keep your engine coolant clean which will prevent premature coolant pump seal failure. These are recommended modifications if you do a lot of mud or submerge your ATV. Special thanks to Traildog formally Tru4wd for posting this write-up.
There are 2 areas that need attention.
1. The overflow bottle has a small hole in the top that draws in muddy water when the engine is cooled, as it would be going through a mud hole. This contaminates the coolant and will in time damage the water pump seal.
The Fix
Find a piece of clear Tygon (clear plastic) tubing of no more than 1/4", you will also need to find/make a hose connector that will fit snugly into the tubing.
Drill out the hole large enough to insert the hose connector and fix it in place (no leaks) then attach the Tygon tubing to it and run the other end up to the air intake tube and hold in place with a tie wrap.
2. (Most important) The main reason the water pump seal failure is contamination from muddy water entering the weep hole under the seal. Muddy water has direct access to the seal via this hole.
The Fix
Find a piece of 1/4" metal tubing (I used stainless steel) about 1" long and about 2 foot of 1/4" Tygon (plastic) tubing.
You will need to taper one end of the metal tubing for approx 1/4" so that it fit's into the weep hole. With a little 5 min epoxy applied to the tapered end, place the tapered end into the weep hole and with a small hammer gently tap into place until snug. Allowing 15 mins for the epoxy to cure properly, slip one end of the Tygon tubing on to the newly made hose connector and run the other end up behind the engine to the frame. Tie wrap at 4 to 6" higher than the weep hole and the let the end hang down at a convenient location.
Most automotive parts stores carry clear plastic tubing and a variety to connectors that can be adapted to do the job.
Edit: You can easily make your own fitting to go into either the overflow bottle cap, or the weep hole out of an automotive grease zerk. Purchase a couple of the small threaded zerks (1/4 inch fine thread) and remove the check-ball from it. This is most easily done by clamping the zerk in a vice or with locking pliers, and filing away at the BACK side of the zerk, until the spring and ball can be removed. Now simply drill and tap the hole to the proper size (again, 1/4 inch, fine thread) being VERY careful not to drill too deep at the weep hole. A few people have found the weep hole to be big enough to tap without drilling the hole larger. Thread the zerk into the hole, and you have a ready-made nipple for attaching the 1/4" tubing. Also, the only permanent mod to the engine case is the threading of the weep hole.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Bom2000
May 13, 2003 10:42 AM
Psycho
Mar 30, 2003 08:11 PM
