Pull Start rope jammed??
Old Aug 18, 2006 | 02:05 AM
  #21
redhedkev's Avatar
Default Pull Start rope jammed??
Originally posted by: xler8ion
Did you remove the starter and check to see if the gear is damaged/jammed? I would check that first since removing the plug made no difference. As to it rolling when you push it you must remember that this is a CVT system and will roll with a little effort even if the engine is jammed as the belt is not engaged.
see im kinda new to this stuff so i dont rlly know what u mean by remove the starter. i dont know were it is. sorry can u tell me were it is located?
Old Aug 18, 2006 | 03:48 AM
  #22
xler8ion's Avatar
You really need to verify the year and model of your quad and the engine model no. The model number IF it is a 98 or any years close to that is generally located on the lower left frame rail-your left as you are sitting on the machine. There should also be model numbers on the recoil housing. The frame model number should begin with an A or other letter followed by various numbers. Is it a trail boss or what? Record the numbers just as they appear in the areas I mentioned. This will help find the starter. There are other ways but let's try this first.
Old Aug 18, 2006 | 08:12 PM
  #23
trailblazzers's Avatar
to find your starter follow the larger wird(red) from your battery to the starter. It shoeld be the easiest way to find the starter. Are you able to do this or should you maybe try to get some in person help from somebody. If you take anything apart make sure you pay attention. You said you took off the recoil cover and nothing was jammed the starter could be on the other side of the bike in the same area.
Post pics we could point out items!
Erik trailblazzers@shaw.ca
Old Aug 28, 2006 | 07:04 PM
  #24
xler8ion's Avatar
rhkev,
What did you find out? Is it fixed??Locate prob???
Old Aug 31, 2006 | 10:40 PM
  #25
BigRic's Avatar
How do I remove the starter from a Polaris 250 Trail Blazer?
Old Jan 25, 2017 | 11:49 AM
  #26
zenobia's Avatar
my bike too is having the same problem! (2004 kawasaki kvf700) but when i took the pull cord off the bike was able to turn over with the electric start.
Dammar
Nov 14, 2015 07:41 AM
Dabears1983
Jun 16, 2015 12:17 PM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
