96 Trail blazer opinion
Hey i have the opportunty to by a 1996 trailblazer for a good price. I was just wondering what is your opinion on the machine? Is it good and reliable? Easier to fix? thanks so much
Decent older machine but they arent worth much.I wouldnt go over $600 because it most likely will need at least a topend job,brakes and tie rod ends.
Hey thanks for the replys I was also wondering... these things are 2 stroke correct? So are they loud like 2 stroke dirtbikes? Also do they smoke like some of the old 2 strokes did when you slow down for a while on a trail? Thanks
Great thanks again. Wats the fuel mix on those 50:1? also would I need to run synthetic oil in it or is it my choice? Also will this this handle well it mabye at the most 2 feet of water/mud besides it getting stuck? Thanks
It's oil injected from the factory, if that works, and either way you can use "polaris blue" I've had good luck with it. 2 feet of mud is taller than your rear tires, wheel speed my friend, it should make it be smart though.
