Polaris Diesel Idle problem - any tech advice?
Old Sep 13, 2006 | 09:18 AM
Vondy's Avatar
Default Polaris Diesel Idle problem - any tech advice?
Can anyone give some tech advice re. 2002 Polaris Diesel 455 idle problem:
Idle is erratic, even when engine warm.
Throttle lever return spring (under engine top cover plate) seems too weak and without modification even a new spring is too weak to overcome the other spring located in handlebar asembly. This allows contacts in handlebar unit to close and stop engine.
I have taken one turn off return spring and adjustment is better, engine stop contact does not close, but idle is still not perfect and varies.
All throttle parts and engine generaly is in good order.
I have full Polaris worksop manual and have followed all setting procedures, although very little information is given re. setting of springs and adjustment of engine governor.
Any advice would be appreciated.
skittero
35
Mar 1, 2019 12:39 AM
neilbedwell
Nov 10, 2018 11:02 AM
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
blaze_master
May 26, 2015 11:18 AM
