polaris sportsman 500 overheating
Old Nov 15, 2006 | 10:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default polaris sportsman 500 overheating
the 500's must not be like the newer ones. i know on my 800 just unplug the temp sensor and the fan will come on. its just a basic ground out sensor. its the easiest to check to see if the fan it self works. as far as air in the systom its not likely unless you have drained the coolant.
Old Nov 15, 2006 | 10:40 PM
carver's Avatar
That's some good information, I'll try that if it happens again. Of course, I hope that it does not.
Old Jan 30, 2009 | 05:37 PM
jschafer's Avatar
Default polaris sportsman 500 overheating"></title><script src=
can i take the thermostat out? will it still overheat. My quad is still overheating. Or what should i use to clean the radiator out with? it is like Zero here.
JIM
Old Aug 9, 2010 | 05:24 PM
fischbone988's Avatar
JIM
DO NOT TAKE THERMOSTAT OUT!!!!! you will than have serious overheating problems thermostat is in there for a reason you take it out and will realy overheat it than you have a good chance of cracking the head i have fixed many of these 4 wheelers 9 times out of 10 its the heat sensor
Old Aug 9, 2010 | 06:06 PM
  #15
Overdrive's Avatar
Originally Posted by carver
. Very easy to replace but I felt raped to pay $94 for the damn thing.]
Yes you got screwed. This switch can be bought at the auto parts store for less than $20.
Polaris also wants a fortune for the rad cap. They are also available at the auto parts for about $6.
Old Aug 15, 2011 | 09:25 AM
  #16
jamesawooten's Avatar
Default Auto Parts Store Radiator cap for Sportsman 500
Anyone know the part number for the Autozone/Advance radiator cap for the Sportsman?
Old Feb 15, 2019 | 07:42 PM
  #17
Brett Hamilton's Avatar
Default Help
Originally Posted by Instigater
If the fan is not turning on, this is the problem. Don't worry about the radiator, YET. Lets get the fan to turn on first. The sensor that controls the fan is on top of the radiator on the back side. You could bypass this switch with the key on to see if the fan comes on. If it does not, keep digging for the cause(bad fan,voltage available, bad wire between your bypass and the fan, ground, etc...) If the fan turns on, good, now look for air in the cooling system or a clogged radiator(inside and out). Check these things out andlet us know!
so my 2001 Polaris 500 keeps over heating
fan was not turning on
bypassed the temp sensor so fan is always on
filled coolant
tried it, did same thing
ran for awhile then light came back on
any ideas what to do next?
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
