93 polaris trail boss
1. check your compression sounds like it is time for a topend job
2.one is a accessory plug not sure on the other(pics would help)
3. either your idle is too high or your front clutch isnt releasing completely or the shift rod needs adjusting or the shift fork inside the tranny is worn.
