how do i change my front gearcase oil?
It is a small pump that screws onto the oil bottle with a hose, the end of the hose has a fitting that screws into the drain hole. Use the markings on the side of the oil bottle to know how much oil you are pumping in. You just need to be fairly quick with the drain plug when you unscrew the hose. The pumps are cheap, less than $5 from any marina.
JackTheKing
07-14-2015 09:09 PM
