clutch question...
Old Mar 14, 2007 | 05:19 PM
Exrider89's Avatar
Default clutch question...
my 02 sportsman 500 stalls when i put it into gear unless i gas it right away and when it gets going at idle its creeping. i'm trying a shim in the secondary clutch first. i have the sec. clutch apart i just need to know where to put the shim does anyone know? or have any other was to solve this?
Old Mar 14, 2007 | 06:11 PM
trailblazermudrunner's Avatar
i think u put the shim on at the end of the shaft.....not quite sure im tryin to reamber how i did it on mi moms
Old Mar 14, 2007 | 06:18 PM
it could also need the primary spider shimed and sten said in another thread that u need a special tool to remove it if it is the spider and from what u are describeing its the spider gear that ur talking about whats the belt deflection should be about the width of a quater laying on its side......
Old Mar 14, 2007 | 08:15 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
exrider, sent you a pm to your question.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
