who has a 2006 polaris 500 efi ?
on the instrument cluster i have that wrench flashing when i start it up.
i believe that is for oil change signal.
i can't remember how to delete that off.
i tried looking in the manual and can't find it in there.........if you know tell me what page.
the only one i come close to is page 43.
it just don't sound correct.
thanks alot
thanks alot
just dont forget to reset it to the hrs you want to service it again. the book says 50 hrs. its pretty easy to do it once you find where rogert said it was.
scooter once you get it into the service mode you go to the one with the wrench and the hourglass in the upper left hand corner, it probably says zero just hold your override button til it goes to off then let off and hold it in again the wrench will start flashing then let off on it and hold it in again and then it will start counting the hours set it to whatever time you want til your next oil change, hope this helps. ive done some deer hunting by nimrod so you are in one of the best deer huntin spots in minnesota, cool[img]i/expressions/face-icon-small-smile.gif[/img]
06, 2006, 500, change, cluster, diagnosis, diagonstic, efi, instrument, oil, polaris, reset, spoortsman, sportsman, wrench
