Scrambler replacement tires
Old Mar 15, 2007 | 04:07 PM
SoupNazi's Avatar
Default Scrambler replacement tires
I got a set of tires and rims off of an '02 Sportsman with 100 miles on them for really cheap, and am wondering if they would be ok to put on a '97 Scrambler 500. I asked a dealer and he said that they wouldn't even bolt up, which is false, and then he said that the scrambler did not have a low range gear so I would burn up some belts while using them. Can anyone verify that?
Old Mar 15, 2007 | 04:53 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i dont have a scam. but its the same as a tblazer i beleave and the rear ones wont bolt up to a sportsmans rim i beleave. as far as bigger tires on it you may need a clutch kit depending on big you go overe stock.
Old Mar 15, 2007 | 06:12 PM
SCRAMMYTODD's Avatar
You don't mention if it's 4x4 or not but my Scram was and the front tires were bigger on the front compared to the rear. I think it would be a good idea to keep the stagger in the tires for 4x4. And Sten is right the bolt pattern is different on the rear.
Reactant
Mar 30, 2022 02:08 AM
JackTheKing
Jul 14, 2015 09:09 PM
rcappie4
Jul 10, 2015 04:54 PM
coolguy420
Jul 9, 2015 09:54 PM
jettman
Jul 6, 2015 12:16 PM
