PROBLEM: Oil Tank Leak
Old Mar 19, 2007 | 02:46 PM
troylee07's Avatar
Default PROBLEM: Oil Tank Leak
I was changing the oil on my 2005 Predatoor TLD, and i went to prime the line like the book says, but when i did, oil started bubbling out of the seam at the top of the oil tank. I have a full HMF system on it and the headers are closer to the tank than the stock headers, would this have caused the leak or something else. Just wonderin if i needed to by a whole new tank or if i could patch up the seam. If i need to buy a new tank where could i find a cheap one but if i could patch it, what kind of sealant should i use? Thanks in advance
Old Mar 19, 2007 | 03:43 PM
la90043's Avatar
home depot has many types of sealants/glues to choose from. also your local auto parts store has many to choose from too. the oil tank came apart from the seam from the heat of the header, make a heat shield to protect it in the future.
Old Mar 19, 2007 | 03:52 PM
troylee07's Avatar
how should i make a heat shield, any hints or recomendations
Old Mar 19, 2007 | 03:54 PM
la90043's Avatar
bend/fold sheet metal in a vise and/or cut to shape with sheers. strap on to header pipe with hose clamp.
Old Mar 19, 2007 | 03:57 PM
la90043's Avatar
or strap it on to the oil tank. there's many ways.............to keep the heat away from the tank
Old Mar 19, 2007 | 04:23 PM
godIlove2ride's Avatar
I would make it from aluminum. Better heat dissipation.
Old Mar 19, 2007 | 04:28 PM
la90043's Avatar
thats right. diamond plate aluminum
Old Mar 19, 2007 | 04:43 PM
troylee07's Avatar
do any of you guys prime it like it says in the book or not
Old Mar 19, 2007 | 04:46 PM
la90043's Avatar
yes, i do..................lol sounds funny
Old Mar 19, 2007 | 04:50 PM
troylee07's Avatar
ok thanks for the help i will give it a shot
franklyme
Oct 21, 2016 07:18 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
mbriggs
Sep 13, 2015 10:47 AM
