AWD & speedo not working 500 sportsman 00
Old Apr 9, 2007 | 07:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default AWD & speedo not working 500 sportsman 00
its either goi8ng to be the sprrdo, or the sensor on the wheel like 2many said thats gone bad.
Old Apr 14, 2007 | 08:00 PM
firefighter421337's Avatar
Hey guys I'm having the same problem with the top gauge not working at all, the over ride switch not being needed to go at a higher speed in reverse, the awd not working, and also my top headlight is not working. So does this sound like that this hall effect sensor is my problem as well my machine is a 2004 sportsman 400.
Thanks guys
Old Apr 14, 2007 | 11:03 PM
Scramman07's Avatar
i had that problem. it was a family of mice living in my headlight pod in the shop over the winter. but not everyones case. if your dial on ur speedo just dont work then its the left wheel sensor they always go. unless u have a cable speedo, i dont know the 2000's. if you have no electrical to the top of the bike it could be the kill switch. my dads 01 had that problem. they are the freakin ones with the kill switch as the start button. if you have that check the kill switch. also check it for crap too. there is so much stuff going on inside that little thing its so stupid. but yea electrical problems suck those are a few things to try other wise go nuts with a test light familiarise yourself and eliminate possibilities.
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Dec 4, 2019 09:38 AM
Rooky
10
Jun 23, 2015 09:35 PM
yellowpolaris
Jun 21, 2015 11:13 AM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
