2000 Sportsman 335 no start
Old May 20, 2007 | 11:20 PM
mallen's Avatar
Default 2000 Sportsman 335 no start
On my Sportsman 335 I can only start it with the recoil. My battery will not hold a charge and with it running the volts are 7.5. I also have to push the reverse override button for reverse to work. I know the battery needs to be replaced but is it the stator that isn't working? Any input would be very helpful. I hate to throw parts at it. Thanks
Old May 21, 2007 | 07:34 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if anything, if you know the batters bad and keep running it you are not doing your charging system any good buy trying to charge a bad batery. most likely the recifer is bad. it should be located in the front up under on the "A" frame looking part of the frame. buy a new battery and charge it. once installed then test it to see whatthe volts are. should be 13.5 plus.
wbfjim
Jun 8, 2015 06:20 PM
1000gade
May 27, 2015 12:37 PM
Fullblast
May 26, 2015 12:38 AM
sportsman500nc
May 7, 2001 05:22 PM
IndyStorm
Apr 18, 2001 10:02 PM
