96 425 magnum elec problems?
Old 06-01-2007, 10:02 PM
buckmaster3rd's Avatar
Default 96 425 magnum elec problems?
My high beam and low beam no longer work, radiator fan has quit working and rear break lights also. My battery doesn't seem to be charging, either. Any ideas? Thanks!
Old 06-01-2007, 11:42 PM
ftwflh's Avatar
Replace all the bulbs and battry and be sure the ground wire is grounded good
Old 06-02-2007, 12:27 AM
Charlie's Avatar
The red wire off the regulator has connector that corrodes a lot. Its about two inches from the regulator which is up by the radiator.
greg74
09-10-2019 03:03 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
ScopeZ_
07-28-2015 01:44 AM
hondarider1234
07-21-2015 11:53 PM
jettman
07-06-2015 12:16 PM
Quick Reply: 96 425 magnum elec problems?
