no front drive in reverse
Old Jul 9, 2007 | 07:08 PM
  #31
dusty's Avatar
Default no front drive in reverse
Hope this isn't against the Forum Rules, but you should read this post from another ATV forum about front cage
Clicky
Old Jul 10, 2007 | 12:59 PM
  #32
adrenalator's Avatar
Dusty:
You my man are the MAN!!!!!
Just confirmed his info and he is right ,total repair cost will be about $160 bucks with all taxes.
Dusty I bow down to you, you are a GOD...LOL
Ok I think I've blowen your horn enough LOL
But really man, it's guys like you that are willing to share info that save everyone money, from all those manufactures that ripe people off with over priced parts.
Cliff
Old Jul 10, 2007 | 02:49 PM
  #33
BigCountryUSA's Avatar
No doubt......I think Adrenalator and I would allow one more big price drop if anyone has any more info! J/K.....Thanks for the info dusty! And now........time to get out the tools.........
Old Jul 10, 2007 | 08:19 PM
  #34
dusty's Avatar
Glad I could help. I'm not sure why there is such a discrepancy in prices, but I know JD Green just raped me on a hydraulic pump for my Backhoe [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 13, 2007 | 05:13 PM
  #35
Well I have to give a big thank you to all the added info, I'm sure it will end up helping alot of people.
I ordered the parts monday and I picked them up today.
The cage is alot more beefie then the old white plastic one it replaces and the rollers a little longer as well, but all in all good looking parts.
So anyways I looked at this job again and said to myself that I really think It could be done with out dropping the ball joints, and with a little jiggeling ,Out it came the whole front diff and all axles where left in the bike.
Total time for completion 28 minutes.
I took it for a test drive and it works like a new one again, glad to have it back to all wheel drive.
If anyone wants any advice doing this replacement, pm me and I will do all I can to help .
Cliff
Oh and if anyone needs a stator plate let me know the kit comes with one and I have a few extra.[img]i/expressions/face-icon-small-smile.gif[/img].
Dusty:
I take it you have a green backhoe what size is it ?I have one too but it's orange and is just a baby at 34 hp.
Old Dec 6, 2007 | 07:51 AM
  #36
fooofs's Avatar
Will the JD parts work on a 02 700? I've just started having this problem and from the other posts pretty much determined my cage is broken.
If they will fit could someone post the partnumbers for the JD parts on this site. I'm running through a web filter that won't let me access the highlifter forum with the part numbers.
Thanks in advance for your help.
Old Dec 6, 2007 | 09:09 AM
  #37
ctateusa1's Avatar
If the 02 700 is the same as the 04 700 then it should, on the other forum he said that he took an 04 700 apart and it was the same plate so I would be pretty confident that the parts would be the same.
Roller Kit-MIA 10666- Identical Match
Cage Kit-MIA10667(Slightly longer, black plastic cage, springs and wear plate)
Total for the 2 kits with tax $91.95. Each kit took approx 2-3 days to come in. Sure beats $330 + shipping from Polaris.
I ALSO GOT THE SEAL KIT FROM JOHN DEERE PART # MIA10654 COST 12.35
Old Dec 7, 2007 | 04:57 AM
  #38
goodblasson's Avatar
what is the roller cage and do I have this on my 96 polaris magnum 4x4?
Old Dec 7, 2007 | 07:39 AM
  #39
fooofs's Avatar
The roller cage is in the front "differential" of the newer polaris awd systems. I believe they started with some models in 02 and by 05 all had it. It replaced the hub style engagement I think you have in your magnum. you can get info on the "differential" at http://www.hilliardcorp.com/view.php?id=FDS-1
the reason I quote differential is there is some debate about it, since it does not actually differentiate speed, but Hilliard uses the term, so I guess it is ok.
If you search for AWD problems you will find quite a bit of info on it as it is not uncommon to have problems with it, however I am fairly confident it doesn't apply to your machine.
Old Dec 31, 2007 | 10:44 AM
  #40
fooofs's Avatar
Just wanted to let you know I installed the John Deere parts last weekend and it works perfect. When I dissasmebled mine I found the thrust bearing between the two asles was bent and missing rollers so I replaced that as well from JD. and it works perfect. Set me back $95 bucks total shipped to my door.
Way cheaper than polaris, and deffinately works. Thanks to whoever originally discovered this!!!
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
D-Hagz
Jul 4, 2015 02:19 AM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
