help a female PLEASE 95ish polaris sportsman 400
Old Jun 30, 2007 | 11:19 AM
fishslab's Avatar
Default help a female PLEASE 95ish polaris sportsman 400
Newer sealed batteries that are AGM do not have a vent. The older ones did. It is most likely your old battery vent line.
Old Jun 30, 2007 | 12:05 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i thought only gel batteries didnt have a vent?
Old Jun 30, 2007 | 01:24 PM
fishslab's Avatar
AGM and gel batteries are very similar technologies. Both will vent, when over heated, through pressure relief valves biult into the battery, but they do not have a vent pickup tube like the lead acid batteries do. They vent directly to atmoshpere if needed. In general, if your charging system is operating normally, they won't need to vent.
Old Jul 2, 2007 | 10:32 PM
debkt's Avatar
It didn't go to the battery so I just pulled the tube from the clamps it was hanging from. Must have been for the old battery. Thanks again for all your help.
Deb
Old Jul 2, 2007 | 10:35 PM
  #15
stendori's Avatar
Super Quad Patrol
I'm watching you!
if it went to the old battery the end would have been right near the battery box. most of them dont have a clamp on them.
Old Jul 3, 2007 | 01:16 AM
  #16
debkt's Avatar
there were two clamps holding the hose to the four wheeler.
Old Jul 3, 2007 | 10:07 AM
  #17
scootergptx's Avatar
Supersock
Hired Gun!
It's has been my past experience working on things, to have a part that the factory installed for no apparent reason. [img]i/expressions/face-icon-small-wink.gif[/img]
I always had referred to them as Non-essential Added Hardware.
Easy way to remember that was, do I need this part? NAH!
So you got it up and running?
Old Jul 5, 2007 | 10:09 PM
  #18
debkt's Avatar
yep. runs just fine.
Old Jul 6, 2007 | 05:18 PM
  #19
500HORIDER's Avatar
hi debkt, 500horider here, the tube is for the battery to vent, my original battery was one you could add water to, but my new maintenance free battery does not have a vent on the battery, i just took the vent tube off and kept in i go back to a battery with a vent, hope this helps, ride on!!!!
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
