2004 Polaris Trailboss problems. PLEASE HELP!!!!!!! DESPERATE!!!!!!!!!
Old Jul 6, 2007 | 12:14 AM
crazeynewf's Avatar
Default 2004 Polaris Trailboss problems. PLEASE HELP!!!!!!! DESPERATE!!!!!!!!!
Quad won't run unless the choke is pulled out half way. I'm desperate. Have a trip to Wisconsin in the morning and it's crapping out on me! Cleaned out the carb, emptied gas, new spark plug and still can't keep it running.
Anyone have a clue on what I can do. Really desperate right now!!!!!!!!!!!!!!!!
Old Jul 6, 2007 | 06:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
first thing i would check is the air filter to make sure its clean and the air intake that the foam isnt blocking it and make sure all the vent lines are clear and not pinched. did you make sure the float was setting level. just a couple of thoughts.
Old Jul 6, 2007 | 09:28 AM
scootergptx's Avatar
Supersock
Hired Gun!
It won't idle at all, or it won't run unless the choke is out?
Almost sounds like a clogged jet.
Supersock
Hired Gun!
And welcome to the forums Crazeynewf. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 6, 2007 | 10:09 AM
crazeynewf's Avatar
Thanks for all the info! Up till 2:30 a.m. trying to get it going. Going to change the oil and give it another run. Wish me luck!
Old Jul 7, 2007 | 11:04 AM
ftwflh's Avatar
Take the carb back off and clean the pilot jet.It is the small long jet with holes in the sides and one hole in the center.ALL holes need to be clear.
Jmuddin284
Jan 19, 2026 07:16 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
