Polaris Clutch Covers
Old Jul 11, 2007 | 03:22 AM
  #21
Trailboss725's Avatar
Default Polaris Clutch Covers
so i have a question, i have a 1988 trailboss 250 4x4 and my outer cover warped completely looks like serious heat damage. but the inner is still good, R u saying that I can switch to a newer cover as long as i switch both inner and outer or ......??
Old Jul 11, 2007 | 05:51 PM
  #22
Ludapower's Avatar
I never anything about that.
All I said was that I replaced my clutch cover.. the biggest part that you can see. I didn't bother taking the whole clutch assembly out just to replace the rear one when I knew it wasn't rubbing.
Old Jul 28, 2007 | 10:25 PM
  #23
Ludapower's Avatar
Just updating for the hell of it.. I'm almost done with the quad... about 450$ in parts.
Changed all oils and greased all parts.
Found a busted CV boot on left side and at the same time I replaced both hub seals because one had been busted for about 5 years time with no oil in the hub lol
Clutch cover still holding up great.
Old Oct 10, 2011 | 04:13 PM
  #24
MLC's Avatar
MLC
Default I'll try anything at this point
Originally Posted by Ludapower
Does everyones clutch cover from below the year 2000 (whatever year they stopped making that design) rub when at idle?
Mines been rubbing for 2 years now and we finally got tired of it. Damn thing is a complete rip off though.. 150$ for the cover.
Anyways while it fixed the problem of the original heat warped cover... I still noticed that the top left section of the cover has no support at all and could easily be moved around so the clutch could hit it from inside.
I made a bracket of 1/4" steel (by 1") going from the top left bolt hole of the bracket to the two bolt holes on the frame on top that normally attach the air breather for the clutch cover onto it.
It's really solid now and we shouldn't have a problem with it for a long time now.
Just wanted to mention it to those that'll need to get their covers replaced.
Thanks Ludapower,
Definitely going to give the "Bracket" a try. We have tried everything with mine, and still the annoying knocking on the clutch cover. You can tighten it up sometimes, and it will last until you go over uneven terrain, and there it is again! We have been fighting with it for over two years. I have a 99 Polaris 500 Remington Edition. Have gotten all the other quirks fixed up except for this one. My husband has an 04 Polaris 500 and does not have the same problem. They changed the clutch covers after 2000, and must have corrected the problem. I also was told about changing to the newer model (after 2000) inner and outer clutch covers, but is very expensive and I havent actually found anyone its worked for.
Did you install the new outer cover first, and then the bracket? Or.. did you try the bracket with your existing 'warped' cover first?
Old Oct 10, 2011 | 04:25 PM
  #25
When you get tired of messing with the brackets, replacement updated cover(#5433540) is $74.17 at Cycle Parts Warehouse! Sometimes the brackets work,a lot of times the noise just keeps coming back as the cover distorts even more and you have to readjust brackets again OPT
Old Oct 10, 2011 | 06:00 PM
  #26
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. your better off just buying the updated cover and no more issue.
Old Oct 11, 2011 | 08:02 AM
  #27
Kerbbirds's Avatar
put the newer cover on my 425 a long time ago, no problems since
Jmuddin284
Jan 19, 2026 07:16 AM
coolguy420
Jul 10, 2015 01:17 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
