99 SP 500 driving me nuts.....
Old Jul 11, 2007 | 03:31 PM
slonez's Avatar
Default 99 SP 500 driving me nuts.....
While riding last week, my machine started spitting and sputtering with the occassional backfire. I stopped to try to figure out what was going on. I noticed that the red and green lights were both lit, and that if I held the override button in, everything worked normal. Now, it has happened again. I can't figure out why the machine all of a sudden started running like this, and why the gear lights are lit, even though the machine was in H. Any help is greatly appreciated.....
Old Jul 11, 2007 | 03:52 PM
TennesseeTider's Avatar
Look for a broken or shorted wire. My buddy's bike did this a couple of weeks ago and his hot light and all other lights came on. He found a broken wire.
Old Jul 13, 2007 | 11:54 PM
slonez's Avatar
Would you mind asking what wire he found broken? This would provide me with an excellent place to start. Thanks for the reply!
Old Jul 14, 2007 | 02:03 AM
polarisbear500's Avatar
hey man, mine did this and this is the fix. on the right side of the wheeler's engine, there is a plastic plug with i think 4 or 5 wires attached. that plug there is causing you problems( or at least it was on mine) it is a cheap little plastic deal that sometimes allows water in it and will cause your wheeler to think it is in override mode. try this before replacing it:
unlpug it and let it air dry for several hours, let the plug hand in a downward position to wick any moisture out. then plug back in and see if that helps. if so, you need to try and seal that plug someway, maybe a small amound of clear silicone around the outer edge. if that doesn't work, then you may need to have it replaced. good luck
Old Sep 11, 2007 | 11:58 AM
slonez's Avatar
polarisbear500, might you be able to clue me in as to where exactly this plug is. I'm going to claim that I've looked and looked, and as of yet I haven't found it. Thanks in advance....
Pehter
Oct 3, 2024 11:00 PM
95wolv
Sep 27, 2024 12:00 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
dannytas
Sep 26, 2017 06:31 PM
Oct 10, 2015 10:20 AM
