POLARIS SP 700 TWIN FUEL/CARB ISSUES
Old Jul 28, 2007 | 03:03 AM
baker7mm's Avatar
Default POLARIS SP 700 TWIN FUEL/CARB ISSUES
Hi guys,
I am having fuel probs with my 700... my quad bogged out after going up a small hill and then would not crank up for 20 minutes. Also fuel was flowing from a tube that runs from the bottom of the carb down to the underbelly skid plate. I finally got it running and it would bearly idle. Then it cranked up and ran fine until I backed up on a small hill. Same problem again, the gas still flows from the tube untill I turned off the gas. Any suggestions... change fuel filter, better gas, carb work.. by the way it is an 04 700 twin with 2500 miles. thanks! RAN IT AGAIN LAST NIGHT ABOUT 10 MILE NO PROBLEMS UNTIL I PUT IT ON MY LOADING RAMPS THEN FUEL FLOWED OUT OF THAT LINE????
Old Jul 28, 2007 | 07:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you have a float issue for sure if its only doing it on hills. need to take the flaot bowl apart and clean and adjust i would guess. my .02
HondaR24
Jul 23, 2015 11:22 AM
nature violator
Jul 3, 2015 08:40 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jun 29, 2015 08:58 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
