scrambler 400 clutch help
Old Aug 21, 2007 | 10:55 PM
Scrambler00's Avatar
Default scrambler 400 clutch help
I'm in a bit of a pickle i just got a AAEN pipe and clutch kit but the their is a gash on the inner sheave of my primary clutch and the mechanic won't touch it unless i get a new clutch. So do i try to find a used clutch, ebay isn't an option unforntunitly so it will be from local wreckers, or a whole new OEM clutch, or the one i like, to buy a comet HPQ clutch. THAN if i buy the HPQ clutch should i still use the aaen clutch kit so it runs with the pipe??? thanks in advance
Old Aug 21, 2007 | 11:59 PM
ftwflh's Avatar
GEt you a used clutch and use your springs and weights.Dont go with the Comet it is too hard to dial in.
Old Aug 22, 2007 | 09:45 AM
ok thanks , so the comet is a no go, and should i try to find any polaris atv clutch and just use my weights and stuff or find a actual scrambler clutch .thanks again for the help.
Old Aug 22, 2007 | 06:43 PM
ftwflh's Avatar
Any non EBS clutch from 94 - up will work with your weights and spring.
Old Aug 23, 2007 | 06:53 PM
drlang's Avatar
I've got 1 off a 94 400l that blew up. 3000 miles and well taken care of if you're interested?
Old Aug 23, 2007 | 08:58 PM
thanks for the offer but i can get one from a local parts place used for the low price of only $300 canadian, a new one is $500 can. thanks for the help guys, can't wait to get the bike back and giver a ride with the new pipe and clutch kit and reeds. CAN'T WAIT!
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
