04 sportsman 700 no low end
I had to replace the valve cover on my 700 because it warped. so I had to remove all of the plastic including the speedo pod and now I have no low end. It will idle but when you hit the throttle it falls flat on it's face. I went through the carb, checked the air filter, checked the intake boot, replaced the plugs and made sure all of the connections were correct. It is NOT fuel injected. any ideas????
make sure you have a 1/8" gap @ the throttle so it wont kick on the etc. you never said if it spits/cuts out/sputters or not. if so its most likey that.
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
