need little help
Old Oct 12, 2007 | 01:58 AM
maa-bell's Avatar
Default need little help
Got a 96 polaris sportsman 500 with a constant ping in engine. The pinging is constant with the RPM's. Any suggestions?
Old Oct 12, 2007 | 08:05 AM
Natal's Avatar
Sounds like u might need some topend work, thats the bad deal with 2 stokes they usually high maintenance, Good Luck
Old Oct 12, 2007 | 04:55 PM
08Renegade500's Avatar
2 stroke 500?
Old Oct 12, 2007 | 08:40 PM
maa-bell's Avatar
It's actually a 4 stoke
Old Oct 12, 2007 | 09:52 PM
xljimmy's Avatar
Valves might need adjusting? Just a thing to check.
Old Oct 12, 2007 | 10:30 PM
maa-bell's Avatar
How hard is it to check the valves?
Old Oct 13, 2007 | 02:33 AM
Kerbbirds's Avatar
pull the gas tank, put the piston at top dead center compression, pull the valve cover and run a feeler gauge under the rocker arms.
Old Oct 13, 2007 | 05:01 AM
maa-bell's Avatar
thanks, i'll try it
Old Oct 13, 2007 | 11:53 AM
sheepdogMSP8117's Avatar
If you have constant ping, the timing might be too far advanced. Or you've got a bad batch of fuel. Try running higher octane and see if that makes a difference. If it doesn't, I'd bet the timing needs to be retarded.
