how to tell if strut is gone
Old Nov 19, 2007 | 10:20 PM
marmon's Avatar
Default how to tell if strut is gone
I was adding heavy duty springs to my 01 sportsman 500 and noticed that when i pulled the strut off it had no compression resistance but had a lots of rebound. Is this strut blown? or is this how they feel byhand?
Old Nov 19, 2007 | 10:23 PM
SCRAMMYTODD's Avatar
Are they both the same?? Maybe try to find another bike to compare it to, but I think thats the way they are supposed to be.
Old Nov 19, 2007 | 10:54 PM
1smokin50's Avatar
They should have resistance both ways.Compression should be firm but not impossible. Rebound should be noticeable but not like let go and watch out!! Look for side to side play as well, or signs of leaks.. . even if slight you should replace the struts.
Old Nov 19, 2007 | 11:43 PM
marmon's Avatar
Ya, they are both the same. i Tried pushig down as hard and fast as possible and there was really no resistance, but when pulling the shaft out, the resistance was similar to what youd expect out of a shock. There was no oil marks or side to side play?
Old Nov 19, 2007 | 11:46 PM
I remember the back of my Scrambler was REALLY soft on compression and stiff on rebound, but I liked the way it rode. My SP is still fairly soft on compression but the stiffer springs make for a good feel when riding.
Old Nov 20, 2007 | 12:45 AM
TLC's Avatar
TLC
Should it not be soft to nothing on compression? Isn,t that the springs job and the strut just manages the spring's rebound?
Old Nov 20, 2007 | 09:31 AM
marmon's Avatar
I don't know? thats what i was hoping, when its together and i push on the front end it doesn't bounce? Maybe the dealer might know, but then again probablly not
Old Nov 20, 2007 | 09:48 AM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
Should it not be soft to nothing on compression? Isn,t that the springs job and the strut just manages the spring's rebound?</end quote></div>
I agree with this statement.
jdunne01
Oct 4, 2015 10:29 AM
WilliamBos
Sep 30, 2015 08:08 AM
79hugger
Aug 30, 2015 02:21 PM
Polarisman1123
Aug 13, 2015 08:13 AM
bonanza 440
Jun 26, 2015 10:01 PM
