put in new piston& rings in 400 scramer 2x4 can u help
blew up motor five years ago pistons shattered and just put back togeteher fresh rebuild don't have manual was told to put oil in dipstick at rear of motor put oil in it and engine smokes very bad and it is not 2 cycle oil injector is working fine seems like crank case oil,we put half quart in dipstick we tried to drain oil out and it quit smoking but engine won't stay running.there was numureous drain plugs not sure what plug was for what any information that you can help with would be appreciated
your talking about the counter balance oil dont run it without it . are you sure the oil pump is good? mine busted and it was stuck open and was real smokey might be out of adjustment .
i still cant figure out why mine smokes the way it does been through the whole thing, someone here should have some ideas.
hoyt
hoyt
Steeldon
09-09-2015 09:38 AM
