Polaris brain buster RUNNING RICH!!!!!
I'm working on a Polaris Big Boss 6x6 and it is running rich. I replaced the needle valve because it had worn square. The new seat is not copper. It is a 1.5 needle because of the fuel pump. Anyways I've checked the fuel level with clear line off of the drain and it does not change when I adjust the float. The float I have also tested and it does not leak. Could the oring on the seat be bypassing? I filled the carb and tried blowing through the inlet and it doesn't seem to pop off. So I don't belive it is leaking. I have also tried changing the enrichment valve to see if it was leaking by and it aint. It will idle but start to pool up on the bell end of the carb. One thing about it is I don't have a manual for the float's actual level it is on order. If someone has a suggestion please help!!!
PS the machine is stock and so is the jetting. And I have soaked and cleaned the carb twice.
skittero
35
03-01-2019 12:39 AM
hoopduerr
06-02-2015 09:01 AM
