starter trouble
Old Dec 13, 2007 | 02:25 PM
trailboss builder's Avatar
Default starter trouble
ok its a 89 trail boss we used a car battery to start it 7?? cold cranking amps
now i put a lawn mower battery on it 230 cold cranking amps but it won turn it
over 230 cca should be enough to start a 250 right? then we put a charger
on it at 30 amps and it works is the starter tired or What?
Old Dec 13, 2007 | 06:03 PM
ftwflh's Avatar
clean the connections and get the right battery
Old Dec 13, 2007 | 06:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
why are you using the wrong batteries in the first place? these wheelers are only designed for a certain amount of voltage/amperage. try what ftwflh suggested.
Old Dec 13, 2007 | 11:48 PM
sorry it is the correct battery I call them lawn mower batterys but i will check the connectors thanx
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
Clint Russell
Sep 25, 2015 03:20 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
