06 450 SP winch solenoid
Hi everyone, looking to see if anyone has run into this problem, My father in-laws bike has a warn winch and a glasier plow. It has started to act up. Sometimes when he goes to lift it you can hear a click and the plow won't lift. Then if he hits out on the winch and then hits in(lift)again it will lift. This is a hit and miss problem, I found the clicking coming from the solenoid under the right front fender, I took it off and checked all of the connections and applied dielectic grease and reinstalled. I also checked the winch connections. It is still doing it. I called the dealer and a new solenoid is $119.00 and it can't be returned so I would like to make sure this is what it is. Has anyone else run into this problem. The solenoid is a 4 post one.
