Bone Head Move Follow-up
Old Jan 7, 2008 | 02:41 PM
egressman's Avatar
Default Bone Head Move Follow-up
My 2006 Sportsman 500 EFI had the motor rebuilt as a result of running it with low oil. (See Bone Head move post if you want the whole story)
Think God for extended warranty!
Dealer fixed it for 50 bucks plus some overnight postage costs.
Ran fine for most of the summer then it started to have a miss after it was rode for a while.
I messed with all the wires under the tank and it seemed to go away.
Today I went to start it and it will not fire. Cranks great!
Pulled the plug and checked it on the frame, no spark?
I also checked oil level, seemed high a little and seems to have a strong smell of gas?? Pulled some out and it light like gas, not oil?
What is going on, I may get a compression gage and check it? Not sure what it will tell me.
Egressman
Old Jan 7, 2008 | 04:38 PM
onesavage's Avatar
WHY ARE DINKING AROUND IF YOU HAVE EXTENDED WARRENTY
Old Jan 7, 2008 | 04:55 PM
deanz400's Avatar
sounds like it's flooded and the plug s bad,but use your warrenty
Old Jan 7, 2008 | 06:05 PM
egressman's Avatar
Well!
I will get it to the dealer but I was woundering why this would happen???
When you say flooded?? It's EFI, can you flood an EFI?
It there a ring problem that is allowing gas to get in the oil?
Part of me things I did something, not sure what I could have done just riding it??
Old Jan 7, 2008 | 07:15 PM
SCRAMMYTODD's Avatar
Defintly sounds flooded and yes very possible with EFI. Change the plug, make sure you have spark after then change the oil and you'll be off to the races again. Just don't run it too long with gas in the oil. That'll be pretty hard on your new engine.
Old Jan 7, 2008 | 09:00 PM
trailbound's Avatar
We just bought a Ranger XP with the 700 EFI twin. The mechanic in the shop said that because this is an open loop efi system, that even though the engine is warm, every time you start it up it goes through an enrichment cycle.
He said in cold weather its best not to start it up alot for small trips, but to let it idle. This would keep it from fouling the plug.
Old Jan 10, 2008 | 08:08 AM
egressman's Avatar
I noticed in my repair manual they talk about circuit breakers?
Where the heck are they?
The coil has a 10 amp breaker.
mywifesquad
8
Sep 21, 2015 08:20 AM
Minimod
Sep 10, 2015 08:03 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
