Removing Decals
Old Jan 21, 2008 | 01:20 PM
  #21
brutus450's Avatar
Default Removing Decals
veggie oil????????? you cooked your plastics
Old Jan 21, 2008 | 01:44 PM
  #22
quad 4's Avatar
Hi Hi....seriously, vegie oil remove the glue, but you have to be very patient. no scratch at all but a little fade.
Old Jan 21, 2008 | 05:06 PM
  #23
dUrTwErX dEsIgNs BMX's Avatar
Hair dryer, pull real slow.
If any left over adhesive is still there, use kerosene and a rag.
Old Jan 21, 2008 | 06:40 PM
  #24
ohnet's Avatar
Quad 4- That goo gone stuff and a razor blade made mine just come right off. You let the goo gone do it's thing for a few minutes and then scrap. By the way, I froze doing this, because my garage was below 40 degrees this weekend. It's been freezing here for weeks now.
Old Mar 16, 2013 | 03:37 PM
  #25
H.M. Gould's Avatar
I have a 98 Sportsman 500. Is the hair dryer the best way to remove the old decals or is there a better way? The hair dryer is taking a very long time read (Hours)
Old Mar 16, 2013 | 06:24 PM
  #26
I used a heat gun at work that would get hotter,but for a 15 year old decal they do get brittle and takes awhile.Just take your time. I always used Goof Off or even rubbing alcohol to remove any residue from the plastic.If you install new decals use a spray bottle with soapy water,wet the area and decal then apply.A little plastic squeegee or sponge works good to remove any air bubbles.Let it dry a while and slowly peel the backing paper off.
Old Mar 16, 2013 | 06:48 PM
  #27
H.M. Gould's Avatar
Default Decal removal, thanks
Thank you all for the advice. I suppose this will have to be a test of my patience if I am hearing you guys correctly. Where can I find new decals for my Sportsman 500, 98 model?
Thanks again,
Herb
Old Mar 16, 2013 | 06:57 PM
  #28
Don't show to be available at several online parts house I've checked,but still show up on the Polaris Parts breakdown. These may be a dealer item only since its 15 years old or decals might be NLA ? Browse There are after market decals,but you'd have to do a little searching unless someone on the forum has a source.
Old Mar 17, 2013 | 07:56 PM
  #29
WilliamBos's Avatar
Heat gun worked great, but mine was new, so that made it easy.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
