700 SPORTSMAN WATER PUMP LEAK.
Old Feb 24, 2008 | 09:28 PM
STEVESRCWORLD's Avatar
Default 700 SPORTSMAN WATER PUMP LEAK.
HELLO ALL,
I have just purchased a used 2004 700 sporty and on my first ride today i noticed that there was coolant leaking from the weep hole on the waterpump. coming out pretty good actually. and then the check engine hot light came on a little later. is it like a car and means that it needs a new waterpump? i have looked at the parts break down online and it doesn't look like the pump comes in one unit like a vehicle. can someone point me in the right direction as to what i need to fix it? seals maybe? thanks
Old Feb 24, 2008 | 11:14 PM
trailbound's Avatar
Sounds like it may just be the o-ring seal behind the water pump cover. Its a plastic black cover I think with a steel reinforcement plate over it. The new ones have an aluminum cover that I think works on most/all twins.
Nondem
Feb 22, 2020 12:20 PM
SDR-II
Sep 29, 2015 01:06 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Mikea1978
Jul 4, 2015 12:37 PM
