Throttle cable adjustment
Old May 2, 2017 | 07:35 PM
asherbeeson's Avatar
i kind of have the some prob. im only 10 and not very atv smart. the hand throttle will move about 1\8th of an inch and then stop. ive took off the carb to try to diagnose it with no luck. its also stuck at full throttle, so i cant ride it. its a 1985 yamaha yfm200 just in case you need to know
Old May 3, 2017 | 12:35 AM
Carb slide can a only go one way,plus check to see if the slide moves up and down with your finger ok. Problem could be in the carb if the bore or slide is worn or the cable needs replacing. Let someone experienced look at it because it's dangerous the way it is.
Old May 3, 2017 | 07:51 PM
Smile thx
thx m8
Old May 6, 2017 | 12:30 PM
Thanks old polaris tech. My uncle is a mechanic and he'll be able to look at it. Thanks for your help.
Cummins Driver
Sep 11, 2019 01:22 PM
GregM
Mar 6, 2018 06:53 AM
dougn85
Aug 5, 2015 07:20 AM
ghost civic
Jul 30, 2015 04:09 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
