front clutch spring
Old May 8, 2008 | 08:26 PM
ftwflh's Avatar
Default front clutch spring
<div class="FTQUOTE"><begin quote>Originally posted by: MECHANIKE
do you happen to know the rates on your spring?</end quote></div>
What do you ride?
The Dalton blk/white is a little much for some utes and 4x4s
It is rated at 39-144
for utes and 4x4s I like an EPI pink 0-140 or Dalton blue 6-144.
You dont get the hard hit on bottom but pulls harder all the way through.
Old May 9, 2008 | 08:44 AM
atv gooroo's Avatar
I have a 04 Sportsman 500 ho and I don't know the ratings on the spring but I like it. Mine doesn't hit that hard at all. If you want it to hit hard you can but it is all up to you. Do a search for Rick Ritter and get his phone number and he will answer any of your questions. Rick recommended this spring and I am glad he did.
Old May 9, 2008 | 11:43 AM
MECHANIKE's Avatar
i got a 01 scram 500 4x4, i just ordered a brite green from epi rates are 17-38-123 hopefully not too extreme concidering the stock blue-green is 0-20-115.
Old May 9, 2008 | 07:43 PM
ftwflh's Avatar
You wont gain a lot but it will be noticable.Set your secondary from 1-1 (stock) to 2-2 after you try the spring.
Old May 9, 2008 | 09:05 PM
  #15
MECHANIKE's Avatar
i got to appreciate that, f-t because aftermans,differ in there ratings,i can tell you, i appreciate the 2-2 secondary change.
Old May 9, 2008 | 10:55 PM
  #16
ftwflh's Avatar
do that after you see how the front spring does so you can tell what is doing what.
Old May 10, 2008 | 11:21 AM
  #17
MECHANIKE's Avatar
10/4 FT
Old May 17, 2008 | 01:34 PM
  #18
MECHANIKE's Avatar
hi again ftwflh,we were talking last week about changing to 2-2 the secondary,well to tell you whats happening,i had a stock blu/grn-0-20-115 to a brite green epi# 17-38-123,looks like next size higher is what i want,but now seems to be higher up in the engines power band which is what i wanted,maybe slipping now?? hard to say, new kevlar belt.will putting it to 2-2 make it tighter or rev more,just curious about its effect.nice looking bikes+ fam.i'll have to lookup where your at in your part of il, i'm in cary il which is 40 from chicago+in mchenry county.thanx
Old May 18, 2008 | 03:10 PM
  #19
ftwflh's Avatar
If you are going with EPI springs I would go with the marroon and stock weights. O go with the Dalton blk/white stock secondary set 2-2 and a set of 10RH weights.
clsharky
Jul 13, 2015 02:07 PM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
