Magnum 325 Clutch kit
I mix and match clutch parts all the time but you need a tach to see what rpms you are pulling.Too many rpms on the top and you will blow a motor in a hurry.the 325/330s have a rather weak rod assembly to begin with.So if you can post what springs and weights are in the 500 kit we can let you know close if it will work.
all the kits I looked at dont tell me anything about the it just says made for sportsman 500 or 500 ho that it comes with pirmary springs, secoundary springs, flywheel weghts, engages at a higher rpm, little to no loss in top speed, made for stock or bigger tires. I'm looking at two kits one called outlaw the other is made by dalton
09-09-2015 06:57 AM
