Axle Torque
Old May 22, 2008 | 10:55 AM
RandyL's Avatar
Default Axle Torque
front hub nut on the 2008 500 is 60lbs.........is that what you need?
rear hub nut is 80lbs
Old May 22, 2008 | 11:03 AM
user493's Avatar
Moto Psycho
Default Axle Torque
Nevermind. [img]i/expressions/face-icon-small-smile.gif[/img] I can't figure out how to delete a post and can just edit it.
Try torqueing to 40 and then go farther until the hole and slot line up. I had to do that with rifle barrels, 35-80 pounds, if you can imagine that. Torque to the minimum and then whatever additional it takes to line up right. I hope that's what you do on that too, that's why I asked earlier if it was a range of 40-80. Somebody must know.
If you're using any brand new parts double torque it. Torque, loosen, torque, loosen, tourque. It will take the burrs off the threads and make it seat better. If you torque new parts down once sometimes they get loose when the burrs and irregularities on the threads flatten out. Double torqueing eliminates that possibility and only takes an extra moment to do.
Old May 22, 2008 | 11:05 AM
94harley's Avatar
Default Axle Torque
Front hub nut torque as per the tech manual.
2005-2006 450/500 - 70 ft lbs
2005 400/500 - 70 ft lbs
Old May 22, 2008 | 11:06 AM
atv gooroo's Avatar
Default Axle Torque
That sounds right and better. I went a head and torqued them at 80. Do yall think that will be okay or do I need to back off? Do yall think that would make the axle hard to get out? Do yall think I ask too many questions? I don't see why it would, being that there is nothing really to hold it back. The axle is lose from the strut but is hung up on the hub.
Old May 22, 2008 | 11:11 AM
  #15
user493's Avatar
Moto Psycho
Default Axle Torque
I'd torque it to 70 and not have anything to worry about.
Old May 22, 2008 | 11:17 AM
  #16
atv gooroo's Avatar
Default Axle Torque
I want to thank you guys but I think that every time someone thanks somebody for the replies they stop replying.
Old May 22, 2008 | 04:18 PM
  #17
RandyL's Avatar
Default Axle Torque
AHhhhhhhhh..............gooroo........I 'll reply..........you welcome Pal. [img]i/expressions/face-icon-small-happy.gif[/img]
All you other guys weren't going to reply on purpose cus he said that eh...........EH!
Old May 22, 2008 | 04:21 PM
  #18
atv gooroo's Avatar
Default Axle Torque
I will make a reply too.[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 22, 2008 | 09:02 PM
  #19
user493's Avatar
Moto Psycho
Default Axle Torque
I'll reply just because I want to know what Randy feeds that critter that makes him run around so much.
Old May 23, 2008 | 11:51 AM
  #20
RandyL's Avatar
Default Axle Torque
He's iust happy. [img]i/expressions/face-icon-small-happy.gif[/img] Kinda mind boggling how he can balance on those tiny feet!
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
01ssls1
Sep 22, 2015 06:50 AM
1000gade
Sep 9, 2015 04:41 PM
