Just bought 94 polaris 400L, have some questions please
Old Jun 4, 2008 | 12:17 AM
user493's Avatar
Moto Psycho
Default Just bought 94 polaris 400L, have some questions please
Harley, when you said you have a 400 but didn't say what model I was just guessing which one. There were several different 400s, like the 2-wheel-drive Sport. If you tell us what model it is, Sportsman, Explorer, etc., then we can suggest appropriate tires.
It would help to know the stock tire sizes too. You can go 1" larger diameter without a new clutch spring or anything on almost any quad. One example made to fit the 12" and 10" wheels is Goodyear MudRunners. I had some on my '01 Sp 500 and the 26" tires would rub sometimes but the 25s didn't. The 25" MudRunners out-performed all other brands of 26" and 27" mud tires back then and are available as Run-Flat tires. You can drive 50 miles with a 2" diameter hole in the sidewall of Run-Flats.
If your 400 is an Explorer, a speedo was never standard equipment to the best of my knowledge.
Old Jun 4, 2008 | 07:58 AM
ftwflh's Avatar
On a new piston always take the cylinder and old piston to the shop that is doing the boring and have them get the Wiesco piston that is needed.
Old Jun 4, 2008 | 10:45 AM
HARLEY_OWNER's Avatar
acually all it is, is a 94 polaris 400L 4x4..it doesnt say if its a sportsman or xplorer.. just 400L front tires are 25 x 8 x 12 and the rear are 25 x 12 x 10
Old Jun 4, 2008 | 10:56 AM
hey also i was readying the guys post about changing tire size is it ok to do? since i have 10's? i could just put 12's alll the way around providing there all the same size
Old Jun 4, 2008 | 07:34 PM
  #15
user493's Avatar
Moto Psycho
I think the stock rear tires were supposed to be 11" wide, not 12", but yeah, you can buy 12" tires <u>and wheels</u>, or you can just buy 12" and 10" tires. It just depends on if you want to spend $$ on wheels or not. If you do go with 12" wheels there will be a LOT more tires to choose from. You can get a whole set already mounted. If you stick with 25" or 26" there should be no problem, you don't need to have any mods done. Let us know what you get.
Old Jun 4, 2008 | 08:25 PM
  #16
ftwflh's Avatar
You can run 12in rims all the way around just keep the height the same front to back.
Just because you go bigger tire dont mean you need a clutch kit!You can adjust the secondary to compensate
neilbedwell
Nov 10, 2018 11:02 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Nowinsky94
Technical and How-To Articles
May 27, 2015 07:29 PM
97TrailBlazer
Dec 6, 1999 10:33 PM
