Polaris 93 350L 4x4
Old Jun 29, 2008 | 05:42 PM
DADOF3's Avatar
Default Polaris 93 350L 4x4
I just got a 93 350L 4x4 from my ex-father inlaw. He has always had trouble with the plug fouling out. I can't get it to start. Has been stiiting for about a year. I have spark, new plug, fuel is flowing fine to the carb, did a compression test. Cranks over about 4 or 5 times and stops at 90. Pulled carb off blew it all out, when you crank it over carb will get wet inside.
Old Jun 29, 2008 | 09:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you mean it only has 90 psi of compression? if so its time for a top end rebuild.
Old Jun 29, 2008 | 10:03 PM
ftwflh's Avatar
time for a topend job
Old Jun 29, 2008 | 10:58 PM
DADOF3's Avatar
What is the compression supposed to be? I have a CLYMER Manual but it doesn't say. I Don't believe anything has ever been done to it since it was bought. Any suggestions on what brand to use for the top end job? Should I go ahead and replace the reeds while I'm at it? Could this have been while the plug kept fouling out or do I need to look at something else while I'm at this?
Old Jun 29, 2008 | 11:24 PM
ftwflh's Avatar
Comp should be very mininmum 100psi 120 is good.Go with a Wiesco piston and polaris gaskets.
AAnd yes low comp will cause plugs to foul.
Old Jun 29, 2008 | 11:43 PM
DADOF3's Avatar
Thanks for the info I appreciate it. Also I read one the other topics and they talked about Removing the oil tank and lines and just mixing your gas yourself. Any suggestions on wether this is a good idea or not. Guy said he burnt his top end up and now that he got rid of it and mixing it himself hasn't had any problems.
Old Jun 30, 2008 | 07:20 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its rare to have a oil pump go bad so alot of us feel to leave it the way it is. much easier to have oil injection then to premix it yourself. imo.
Old Jun 30, 2008 | 07:58 AM
ftwflh's Avatar
Keep the injection.Just clean the mud out of the pump housing at times.
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
cornermike
Jul 30, 2015 06:37 AM
