93 Sportsman 350 4x4
Old Jul 8, 2008 | 11:49 AM
Visions's Avatar
Default 93 Sportsman 350 4x4
Hello everyone... Just joined the forum today looking to tap your experience.
Just obtained a broken down Sportsman 350 and trying to decide to over haul or not. I pulled the head and cylinder to find burned/melted piston and scarred cylinder. Cylinder looks like it can be bored within oversize tolerances and piston/rings replaced. I was surprised to find the crankcase full of water however. As all my experience with 2 stroke engines have been with air cooled models, can anyone give me ideas how the coolant got here? Is this normal? Is there potentially a broken internal cover, hose, etc...
Can anyone make a recommendation on a good shop manual?
Also, if you have done this before and regretted it, I would appreciate your comments here also.
Thanks.
Old Jul 8, 2008 | 11:56 AM
TLC's Avatar
TLC
The way the coolant gets in the crank is usually a bad head gasket or water pump seal.
Old Jul 8, 2008 | 12:24 PM
kukerdan's Avatar
long live the classic 2 stroke 4x4 's !
Old Jul 8, 2008 | 07:32 PM
ftwflh's Avatar
Check the counter balance for oil and if it is clean and no sign of water I would do a topend if the counter balance is bad part it out
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
