feeling like iam running out of gas
well i had to take it to the dealer and the mech. there adjusted the float up alittle and its alot better but still needs to be adjusted alittle bit more it doing alot better but on really steep hills it still runs out of gas ........its a step in the right direction
well i made a second float adjustment this time did it myself and the 4oo is running like its been hit in the tail with buckshot pulling the hills like its mad at them thanks for all the tips ........
#15
<div class="FTQUOTE"><begin quote>Originally posted by: RABBITHUNTER
hey guys iam new to this atv i have a sportsman 400 56 hours around 280 miles when i am on a steep hill it will sputter and almost stop i put it in l gear and it willpull the hill but still sputtering when i get on level ground it will take off and run all out clears right up i fell that its in the carb but would like to hear from the guys here thank for any help....its a 2004....</end quote></div>
Sounds like the float level is too low or you have a bad float in in the carb.
bgky
Jun 29, 2015 01:40 PM
