scrambler 400 front suspension
Old Jan 30, 2001 | 11:32 AM
bubba1005's Avatar
Does anyone have any good ways to make the front suspension on the scrambler less hard. I have seen that works and fox make struts and progressive has a spring kit. Which way should I go.
2000 scrambler 400 4x4
Old Jan 31, 2001 | 01:15 PM
jim's Avatar
jim
I went w/ the Works struts which is a very smooth ride compaired to stock. There is unseated sag on the Works & then it sags even more when seated. Plus its adjustable so you can let the air out to make it softer yet which you can probably do since it's set up for 5' jumps & if you dont do jumps then you can back off the presure. It is a very soft ride & is great on jumps too.
Jim Maloney 98 400 Scrambler
http://photos.yahoo.com/jim400scram
Old Jan 31, 2001 | 02:10 PM
Xplor's Avatar
I also went with the Works. I aadded them to the HotSeat Dual Rate springs. Amazing difference now!
Old Jan 31, 2001 | 02:43 PM
bubba1005's Avatar
thanx for the info guys. Has anyone tried the fox struts. If so how are they. the hot seat springs I did not see them in the catalog are they new?
Thanx,
bubba1005
Old Jan 31, 2001 | 02:55 PM
thenewfiebullet's Avatar
WHat's the cost for those Works struts?
Old Jan 31, 2001 | 03:02 PM
bubba1005's Avatar
Thanx,
bubba1005
Old Jan 31, 2001 | 04:12 PM
EasterEgg's Avatar
bubba
I just purchased the Polaris long travel Fox struts for my Scram also I had the rear one rebuilt. They are supposed to be here tomorrow or friday. I was going to go with just the dual rate springs but I saw that the factory springs were dual rate. I decided to improve the dampening first and see what that gives me. Plus now all my shocks & struts are rebuildable.
When they`re installed, hopefully this weekend, I`ll go jump some snow banks and see if there is a noticeable difference. HTH
98 Scrambler 500
00 Trailblazer 250
See my pic`s at http://www.picturetrail.com/riskracing
Old Jan 31, 2001 | 06:05 PM
Xplor's Avatar
Works "steeler" struts go for around 239$ per pair. The dual rate springs have been around for a year or so and are also very nice.(around 300$ for front and rear) I have only had one "real" event happen with them so far to show me they work better than stock:
My buddy was stuck in the snow so I decided to go give him a hand. Being on a road and seeing a 3 foot high snowbank I decided to plow through the powder. Unfortunately under that powder was a curb and some hard icy snow. I went flying strait up, not to high, but came down very plush. If I would have had the stock suspension it just would not of handled as good and I would have ended up eating my handle bars again. Well worth investing in.
Old Jan 31, 2001 | 09:37 PM
MNXPLORER's Avatar
DO the Works struts fit the new style Sachs strut housings? You know the struts that bottle neck down where they go into the casing? The ones found on 1999 and up models? Thanx
Old Feb 1, 2001 | 07:57 AM
EasterEgg's Avatar
Works should have something to fit, 99 is the only year for the Sachs. 98 & under use Gabriel and 00 and up use Fox. Polaris lists the long travel Fox struts available for all years except 99 with Sachs. HTH
98 Scrambler 500
00 Trailblazer 250
See my pic`s at [URL}http://www.picturetrail.com/riskracing[/URL]
