2005-700 fuel pump problems Fixed it .
Old Oct 13, 2008 | 10:54 PM
Kerbbirds's Avatar
Default 2005-700 fuel pump problems Fixed it .
Working on a 2005-700, the fuel pump is not coming on when you turn on the key, I hooked 12 volts to te pump directly and it will run, but not getting 12 volts through wiring, checked all wires and all three have continuity but only showing 5 volts on red-white wire which should be the positive , purple white goes to speedometer and is only showing 4 volts, any ideas? is there a fuse? anyone have a wiring diagram for it? Found orange wire pulled out of bottom of fuse box.
Old Oct 14, 2008 | 08:54 AM
Kerbbirds's Avatar
Bump, any ideas?
Old Oct 15, 2008 | 07:54 AM
Kerbbirds's Avatar
bump
green giant
Jul 13, 2017 12:07 PM
Stillonit
Aug 5, 2015 07:46 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
