NEED SERVICE MANUAL FOR 06 SPORTSMAN 500 EFI ASAP
I need a manual because I just bought a ATV that had a blown engine. I might be rebuilding it. But I might also replace the engine with one from a salvage yard. I also would like one just to have one on hand. Really like the having it on PDF. I will take the 08 version for now. Just email me the info. Polaris88@mchsi.com Thanks for the replys!!
This will get you started http://www.sendspace.com/file/bhd61z
its for a 400/500 96-03 but the frame and 500 h.o motor has not changed since 2001 and many other things .
The motor may have a carb and not the efi throttle body but the motor has not changed a bit.
THis quad had a tuff life. I had picked it up at a insurance auction. It was suppouse to be a flood unit with a lock up motor. I can tell it was not a flood unit. It look like someone got it stuck and burnt the engine up trying to get unstuck. When I pulled the engine there was hardly any antifreez left in it and low oil. Once I pulled the engine apart I could see why there was hardly any antifreez in it. It has a crack cylinder, piston is totaly shot and cylinder has some damage. I have not gotten down to the crank yet but it is not looking good there. Parts of the piston broke off and is wedge into the crank. So I think this thing went BOOOOM.
