how do i take the axle off a trail boss 325?
Most of the removal is obvious. But there are 2 big jam nuts(one on each side of the housing). I think you can remove theone on the right side along with the chain and sprocket. It should slide out the left side. I don't think it can be removed from the right side. I may be wrong but I don't think the axle design will not let it.
good chance you will have to use a cutting tool to cut the axle nuts off and replace them.Easier than fighting to get them off.
