Front hub engagement trouble
Old Feb 2, 2001 | 08:37 PM
stub's Avatar
I have read alot of post on the front hub problem
and have not had any success in fixing mine either.They engage automatically when you spin the rear tires in two wheel drive.The only thing i can't understand
is if you take the hubs apart and pull the armature plates from the magnets and put them back together it will work fine until you use the
AWD button. It acts like the magnet is not demagnitizing all the way because the armature plate is kind of stuck until you pull it away.
The outter magnet pole is suppose to be ajustable. Does anyone know how to adjust it?
That's about the only thing i haven't tried.
1998 Sp500 2000 miles.ANY IDEAS.
Old Feb 3, 2001 | 10:52 AM
Farmr123's Avatar
To adjust it, you just tap on it using a non-marring punch. The outer sleeve should be able to slide in & out. Adjust it as clost to even as humanly possible or so there is a gap of .001 when holding a straightedge across from the outer to inner magnet poles. Good luck.
Old Feb 3, 2001 | 11:01 AM
scramblerjer's Avatar
this whole front hub thing is disturbing. polaris has to know they have a problem with this and it should be a recall!!! is this the price we have to pay for true all wheel drive? i wish i could put lockout hubs on it like a truck!!!!!!
Old Feb 4, 2001 | 06:18 PM
sweetcorn's Avatar
Mine have worked fine since disassembly and reassembly.
heath legg
Jul 24, 2015 01:01 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
tporath
Jul 11, 2015 12:31 PM
coolguy420
Jul 10, 2015 01:17 AM
