Slipping belt on express 300
oh ok, yeah it does leave small gaps, oh well, ive also been told to use anti slip belts but then ive heard that they suck so im in a bit of a rut because there quite expensive
when you go through the water like that, and you get out the other side, put it in Neutral and rev the engine a little bit for about 5 minutes. will usually dry everything out.
Up grade to a newer style of belt cover will help 03- Up 250 Trailblazer will interchange and are made better.
Still wont be able to fly through water.
AFter going through water i have to let it sit for about 10 minutes for everything to dry out but somtimes if i put it in low it will go off the bat .i will try new cover and silicone for the edges and a new drain plug
Jeff Roper
Feb 1, 2022 11:48 AM
