over heat
Old Nov 12, 2008 | 11:57 AM
kmfc's Avatar
Default over heat
2004-600 twin hot lite comes on but not realy hot replaced sencor and running temp gauge any ideas
Old Nov 12, 2008 | 02:14 PM
MECHANIKE's Avatar
Default over heat
is the fan functioning?
Old Nov 13, 2008 | 11:43 AM
Sport400inOH's Avatar
Default over heat
Check your coolant level - It might be too low. Also, make sure that your coolant pump (AKA water pump) is functioning. If your coolant isn't circulating properly, it may be getting hot in 1 place (like the head), but not another. With the engine cold, open the radiator cap can start the engine. You should be able to see the coolant flowing...
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
poutlaw525
Sep 9, 2015 03:19 AM
