Transmission drain plug location?
Old Dec 31, 2008 | 08:45 AM
The original Firehawk's Avatar
Default Transmission drain plug location?
Hi all.
First time poster here and glad to see a great forum like this exists!
I own a second hand Polaris Sportsman 700 4x4 and just replaced tie rods and changed all the fluids, oil/filter, front gear case and rear gearcase. Upcoming project is to replace ball joints and the topic that brings me here...
I went to replace the transmission fluid and I found the fill plug but cannot find the drain plug!!
The manual said something about gaining access to it by removing the "prop shaft sheild"?
Can any one shed some light on this? I'm stumped!
Old Dec 31, 2008 | 08:54 AM
roofdogbill's Avatar
my kids trailboss the plug was under the frame.
Old Dec 31, 2008 | 09:01 AM
<div class="FTQUOTE"><begin quote>Originally posted by: roofdogbill
my kids trailboss the plug was under the frame.</end quote></div>
Yup, that's the logical place to put it with the rest of the drain plugs for the engine and the likes with access holes in the frame but, unless I'm as blind as a bat, the transmission plug isn't... I'll double check it again.
Old Dec 31, 2008 | 10:37 AM
I found it...
After using my drop light, I found the elusive plug.
It doesn't face down like the rest of the drain plugs but horizontally.
It uses a 7/16 box wrench for removal. There is a rectangular hole in the frame directly under the tranny to access it.
greg74
Sep 10, 2019 03:03 PM
SDR-II
Sep 29, 2015 01:06 AM
ScopeZ_
Jul 28, 2015 01:44 AM
kdg723
Jul 25, 2015 01:20 PM
Captjay
Jul 23, 2015 12:33 PM
